Hi,
Trying to install a water pressure gauge on my Johnson V4 120hp outboard.
Just not sure where to tap it in on the engine.
I found that the connection included in the kit do fit in the threaded holes on the cooling covers (one threaded hole on each side of engine), its just that I don?t know if this is the correct place and the holes are of-course closed in the bottom.. Should I just drill a hole through the bottom or what?..
The arrow in the picture point at the hole that I mention above.
