I have a 1979 4hp evinrude and I'm thinking of putting a fuel filter on the fuel line. The concern I have is that the fuel filter would cause too much resistance since fuel flow relies on gravity feed only.
Also I would like to run the motor on a 25:1 mixture as this is what my main motor uses. Would this mixture tend to foul the plugs?
Thanks Kevin
Thanks Kevin
