1982 4 hp evinrude would idlle but stalled when powered up was told leaking seals or head gasket. installed all new seals and gaskets was told rings and pistons were fine i have 70 psi in both pistons is this the right compression or should i have installed new rings haven,t fired it up yet but if compression is to low would new rings help
