Model NUmber ?
Any tricks I need to know? Looks like you wind the spring so the cord is wrapped all the way up, replace the screw, 4 screws to hold the cowling, replace bottom half and knobs, tighten everything up and done. Any suggestions will be greatly appreciated.
On the outside.... The screw and lockwasher.
On the inside.... Spring goes in first, then the pulley, then the spindle. The pawl and springs should be self explanatory. The spindle usually has a locking pin and if so, make sure it's inserted properly. A hand held impact screwdriver is a good tool to make sure that locking screw is tightened securely. A drop or two of Loc-Tite on the threads would be a good idea also.
With the unit assembled and on the bench upside down, hand crank the pulley/spring counterclockwise, insert the pull cord and handle, then let the spring retract the cord... that's it.
