The motor ran decent 6 years ago, then sat unused. I overhauled it last summer with all new wiring, gas lines, impeller, coils, condenser, and carb kit but she absolutely will not run at low throttle. I adjusted the needles several times and even went through the carb again thinking there was a blockage. Slow speed needle looks ok, and new packing didnt help. Motor will fire up pretty good, then as soon as I pull throttle back it immediately dies. Using a trolling motor to get around the dock, I took her out on the lake and ran 1/2 tank of gas at medium-high throttle. No improvement.
At this point, I am close to throwing in the towel and buying a new motor but I was convinced by the restoration forum to see if you guys had any ideas to fix the Evinrude. The compression is decent (115 and 113) so I think she has life left. Im definitely a weekend mechanic, but I can follow a manual and any help would be much appreciated. BTW, my boat is a 57' Lonestar King Commander and the motor is model RDE-17.
