Found it n that fixed it... Sadly tach still doesn't work? It charges the batteries, it can run with the hot terminal off... So rectifier/regulator is good... Plus a brand new tach? Why won't it work???
If your 'hot terminal' is the battery positive terminal then it's likely you have cooked your rectifier.It charges the batteries, it can run with the hot terminal off... So rectifier/regulator is good.
