boatingdudebmk
- Mar 27, 2013
- 24
Hello All,
I have a 25hp Evinrude that I have posted about before on this forum, but a new problem has come up. There is no water pumping from the telltale.
Some notes: I was using ear muffs to supply water to the engine, and it may not have been enough water.
I have dropped the lower end, and the water pump and gaskets are fine.
The engine isn't running perfectly, but it was running at a high enough RPM and for a long enough time for water to get out of the tell tale. Since im still working on the motor running and idling, I can't really test it just quite yet. I'll have time for that this weekend.
Should I try putting the lower end in a trough of clean water and try it from there? I feel like there wasn't enough water pressure, but not sure. Could not enough water be the problem?
All of the connections are good in the shaft, so I can say its not that.
Any suggestions?
Also, what could be the problem with the engine not idling? I have having problems getting it to keep running, but I have broken down the carb, cleaned and adjusted it. Ask any clarifying questions if you have them! Thanks so much!
Any suggestions?
