I've been working on an 85 Johnson 50 hp outboard on a boat given to me. the boat had been sitting for at least 10 years in a garage. so far i have changed the spark plugs, starter solenoid, got a new starting battery, ditched the vro for a regular fuel pump, and cleaned the carbs twice and used rebuild kits.
It is hard to start. I hear the click if i push in the key, and that seems to be working. It starts easier when i hold the throttle on the carbs wide open. But it will eventually peters out, and it cuts of if i bring it back to idle. I have cleaned the small idle jet and don't know what else to do.
What would cause this? Also is it possible to work the throttle on this remote control without putting it in gear? There is a lever on the side but when it's up, the key does nothing and the throttle cannot move.
