Hi, I'm the new guy, Been boating, fishing, diving, Fla., Bahamas, Cuba etc. since about 1947
I have a problem with my 1999 35hp Johnson, last time I ran it I had good water coming from the weep hole, today no water. I took the thermostat out put the cap back on started it up and still no water, So the problem must be either the impeller or the tube in the lower housing is broken or came off ( I'm guessing )
How do I remove the lower unit, does the gear shift have to be in F,N, or R ?
Where is the shifter dis-connect ?
Any thing special I need to know
I've changed many water pumps but never on this engine. I need all the help I can get.
JAY
JAY
