boxchevyman
- Mar 16, 2014
- 61
Hello im new to working on old outboards but possess some mechanical know how. I have the Clymer manual for my motor and it has been very helpful. I also have checked out the TOP SECRET files. But I need some advice on how to wire up my ignition kill switch on my 1960 Evinrude lark 2. The factory Key switch is busted (key is tore off in slot) so I was thinking about wiring up a push button start and toggle switch kill switch? So does this circuit apply voltage to the vacuum kill switch or does this just complete the ground?
So in other words do I just take the wire that goes to the vacuum switch to one end of the toggle kill switch and then the other end goes to the ground? Or am I reading the wiring diagram wrong?
Thanks a bunch.
James
Thanks a bunch.
James
