1993 48 hp Evinrude - The engine cranks and runs when first put in the water. When starting out I trim the motor and drive boat for a while and shut the engine off. Engine will not restart and a fuse will be blown. After changing the fuse engine starts and runs fine. If the power trim switch is actuated the motor will continue to run but the next time I try to start the motor the fuse will be blown. Change the fuse and the engine cranks and runs. Take the boat out of the water for a few days and put it back in and it works fine for a while then the fuse blows.
Power trim works fine and will not blow a fuse while the engine is not running. I removed the power trim and immersed it in water to see if the motor was getting wet and it works fine under water. The rear trim switch is ok.
I can't find a short in any of the wiring and all connections are tight. i have not disassembled the shift assembly yet. Could there be a problem with the ignition switch or the trim switch in the shifter.
Does anyone have an idea what the problem may be.
