1976 Johnson 70 Hp carb spring question
jif102
Over the weekend I decided to clean and rebuild my carbs for the motor. I did not take a picture of the carbs prior to taking them off the motor. When I removed the middle carb a spring fell off. The attached picture shows the spring. I cannot figure out where the spring goes. That is the last item I need to put back together.
Can anyone identify the spring and its proper location on the carb leakage?
thanks for the help
Re: 1976 Johnson 70 Hp carb spring question
The purpose of that spring is to hold the choke flapper open at full throttle.--Someone will likely post a picture for you.
jif102
Thanks. I have been trying to find a picture of diagram to show its location. As soon as I see something I can get it back in place. Next time take pics before tearing apart.
thanks
jif102
Can someone provide a picture of this spring in the correct location? I have been searching through manuals and online photos and can't locate it.
thanks
