klamathboat
- Mar 22, 2014
- 1
New to forum and just purchased a Klamath center console 16ft with 40hp Johnson motor the problem is with the tilt trim manual one can't get the motor to tilt up noticed the cable has a tear in the shielding and when you try to pull the tilt handle towards the prop it stretches the cable out of the cover is there a way to free up the cable to get the motor to tilt ,by yourself it's a pain to try to move. Also can not find I'D for motor on one of the freeze plugs the number is G4293626 want a manual but need to find out year and model the motor cover has VRO but no VRO on motor plugs are QL78C any help or feed back is appreciated.Thanks Forum
