I have a 4 hp evinrude with a leaking fuel tap(part number 389701).An oring had been used to try and seal it by previous owner but it didn't work ,so I'm thinking that packing washers are used to seal the tap when it' unscrewed into the open position. If someone knows what is used to seal these fuel taps and where you can get it from it would be much appreciated.
Regards Kevin
Regards Kevin
