Re: 115hp Johnson Seahorse...help with apprximate age
It could be a '77-'79. Does it have a tell tale on the starboard side of the motor? They started putting tell tales on in '78. What is the serial number?
Looks like a 1977. Cowling decal design looks a lot like the factory parts diagram. No power trim. If it had trim-the 77 trim was the old-style which mounted outboard of the transom brackets. You can confirm using boobie's i.d. method. Here is a pic of the core plug he refers to. The 77 used a single power pack. The 78 and up used two-for a number of years.
