Hey guys- im hoping to pick the brains of any one with experience with this outboard. Heres the story so far, ive had it a few years never used it a great deal but never had any issues with it, i recently moved and didnt get a chance to run it up for a few months. Thursday last week i decided to give her a run and she started and ran with no worries at all, come saturday morning and i cant get her to start, in fact ive tinkered with it every day between then and now and still dont have any progress! So this is what ive done so far;
-Ditched the fuel and replaced with new,
-drained and Sprayed carby cleaner in the carbs, removed the top carb as its much easier to look at and it was spotless.
-Checked spark and it appears good, even replaced spark plugs.
-i damaged one of the spark leads during my investigation but have since fixed it and tested for continuity-all good.
-I compression tested the cylinders, top 85 psi and bott 90 psi which seems low to me but i dont have a manual to check it against.
-Ive put aerostart in it several times and have put fuel in through the spark plug holes afew times aswell, cant get it to fire at all.
-with the spark plugs out ive turned it over and it appears to have a mist coming out so i believe fuel is coming through good.
-also took the hose of the top of what i assume is the fuel pump when not running, when i squeeze the fuel bulb i get fuel there.
So my conclusions are Fuel is good and spark is good. Im thinking the timing may be out, ive heard about the flywheel woodruff key can shear throwing the timing out or that compression is my issue.
Any thoughts guys as its becoming a real pain. Thanks in advance for your responses.
Oh yeah ive cleaned and tightened battery terminals, and have been alternating between 2 batteries and always charging the out of use one overnight.
