Howdy new to this forum
I have an 89 Johnson 88hp well after it sits for a long while (overnight) it won't just start right up turns over fine, there is wat looks like a little valve not directly on top of the carbs just in front of it tht has to hoses tht run to the top of the carbs an will turn 180 degrees and when first starting it I have to turn it in order to get it going then turn it back when I'm running
Wat is the function of this an how do I bypass or fix it hate always have to pull the cowl off to first start
