Re: 77 Johnson 140, stalls when put in either gear
Correct. That engine will seem to run just fine, sitting on the trailer, running on the garden hose-when actually running on only 2 or 3 cyls. Once you dunk it in the water, the exhaust is 20" underwater and you put it in gear, you need all 4 cyls firing. Check your spark-esp after the engine is fully warmed up. Either a cyl drop test, or use an inductive timing light to check spark on each plugwire.
