hello,
i am helping a buddy wire up a new ignition switch in his boat. he lost the key so now we are stuck where we are at. the boat has a 92 Johnson 48 hp. the problem i have is that it has had several ignitions and motors on it so the wiring looks like spaghetti. none of the diagrams that Ive found are helping and the existing switch isn't labeled on the back of it. if it were labeled this would be pretty simple.
What i want to do is run new wires from the motor all the way to the ignition switch. at that point I would basically have color coded wires that are the same on each end. can anyone help me determine what wires I need to tag at the motor end for everything on my ignition switch? if it helps he has a push to choke system.
