mr gibbs2
- Aug 20, 2004
- 121
Hello pickup up a newer motor for my boat ran good when I Looked at it good compression ran well started well . Came back pickup motor mounted it on stand. Has system check ,no spark removed harness plug (6) wire purple one, left the other,jump start with remote start switch .now I have spark ,so it must be from the plug back possible the key switch.Is there anyway to test the switch?,are the pols the same as the older red plug harness .it also seams that if it wiggle the key the tach moves.any ideas?thanks
