Well I have been working on the boat getting it ready and noticed the motor was turning over really slow and then would spin fast and crank ever so often. I thought it was the battery so took it and charged it and it did the same thing. So I was trying it the other day and the starter spun but didn't start the motor so I turned the key again and a click from the solenoid is all I get. I took the battery and had it tested and they said it was fine. I checked the voltage at the solenoid and it was 12.6 and then checked on the starter post and it was 12.5 with the key turned and yet the starter doesn't do anything. I did notice that there is a bare cable wire that looks like a ground strap maybe coming from the ground bolt on the starter down toward the lower cowling that is broke in half. I am not sure what this is for or is it needed. I think the starter is bad but wanted to make sure before I went through taking it off cause it doesn't look to fun.
Thanks
Thanks
