chuexiong1
- Sep 8, 2013
- 15
2001 Evinrude Ficht Check Engine Low voltage/Excessive battery load & not charging
2001 Evinrude Ficht Model: E135FSXSIF
Before I had problems of high voltage and low voltage, but I thought I fixed it since it hasn't come on for many fishing trips in the past 3-4 months. Just a few nights ago, I took the boat out for some sturgeon fishing. Everything was fine in the beginning. Getting ready to come back to the launch, I crank the motor and it weakly turned over. She still fired up though unexpectedly, but once she's running, the check engine light quickly comes on. She ran fine all the way back to the launch.
Got home and check the battery. It was drained out. I recharged the battery and she fired right up fine with no check engine light. With the engine running, I used a multimeter to test the voltage at the battery. It reads 12.5 at idle and stays at 12.5 when I increase the rpm up to 1500rpm. Change battery and tried again. Same result. Hooked it up to the software and the check engine light was for low voltage/excessive battery load, which proves the battery was drained out. The voltage stays constant at 12.5 when idling and revving. Besides this problem, she runs great and fires up great with a fully charged battery.
My guess is the outboard is not charging the battery.
I've been reading and researching and believe it is the rectifier/regulator in the EMM? Just need confirmation or some help to steer me in the right direction.
Thanks.
Thanks.
