Motor running, 12 volts to knife connectors green wire N, green-blue-R, no voltage-F, will not shift, took lower unit off, opened solenoid housing cover, took solenoids out to check for bad wires and noticed lower unit oil approx 2-1/2 inches from top of solenoid cover, lower solenoid would have been submerged in oil, Is this normal? Had recently replaced lower unit premium blend oil. Need to rule out solenoid problem before focusing on the dreaded oil pump. Thanks for any input,have to keep going with this project, motor is just too nice to part out.
