I had to change the power pack on my 1974 70 hp. The manual says to check the ignition timing after this is done. Set to 20 degrees BTDC at 4500 rpm IN GEAR. Looking for some guidance.
I found this from Joe Reeves in the Top Secret files. Sounds nice that this can be done without running the engine.
http://forums.iboats.com/engine-fre...q/joe-reeves-wot-timing-procedure-228183.html
I will need to pick up a timing light. Any thoughts on a $20 reliable one for this one time use? I see they sell inductive ones now. Is there a particular one that functions with these 2 stroke CD ignitions?
Thanks all.
Thanks all.
