If I'm seeing things right...I have two fuel drain lines coming from the intake manifold (front) side of the engine (one near the bottom and one mid-way up between the carbs) and going around, one each to the sides of the block. One lands under the starter solenoid on the port side and the other lands under an electrical terminal block on the starboard side. If I pull the hose off the fitting on the starboard side of the engine and manipulate it with a syringe, I can only suck some fuel through the hose, and can't push any alcohol back into the engine. Pulling the hose off the fitting on the port side I can initially suck some fuel through, and then easily push alcohol back into the manifold end of the hose...so the check valve is not checking at the lower fitting on the intake side of the engine...
So...if the drain system check valve is stuck open, could this affect the running of the engine? My issue is generally that after a lot of low speed puttering, the engine frequently shuts down when going into or hanging in Neutral, randomly, and starts right back up with a flick of the key.
I would appreciate confirmation from someone that knows that I have a bad check valve and this could be contributing to my slow/idle random stalling problem...
Fair Winds and Following Seas, Zig
