Re: 1976 85 hp Evinrude wont start after pulling A tube
When OMC went to the single power packs in the late 80's they came out with the SLOW system which would reduce engine rpm's to 2500 during an overheat. Yours has no such type of either a cutout or rpm limiter system. It is likely you have a weak component in the ignition system. Weak components tend to work when just started (cold.) Once the engine warms up to normal operating temps, they can act up, esp if idling for a while (the engine warms slightly more at idle.) If it starts back up after the engine cools, the ignition system is a good place to start looking for gremlins. So, follow boobie's suggestion, response #2, above.
