Seahorse16
- Jun 23, 2013
- 86
Doing an overhaul on a 1976 Johnson 15 hp I picked up last fall. All the fuel lines are shot, including the line from gas tank. I replaced that (easy to find obviously) and I found a fuel line that goes from male connector on engine housing to fuel pump. This line was slightly smaller than line from gas tank. Now I need an even smaller line that runs from fuel pump to carb. The local hardware store has this smaller size, but it is clear in color. Would this work? I'm worried it may not withstand the heat off engine. Any other ideas to obtain this fuel line? Does it need to be black hose?
Thx!
Thx!
