Re: 1985 Johnson 150 bogging down
You have not posted the model number of this powerhead. OMC made two types of 150's that year. The straight 150 and the high perf 150S-(the GT/XP version-about 165 actual crank hp.) The compression is lower on the normal 150. The basic 150 will have the stock 328324/325 heads, I'd expect compression to be about 90 on each cyl, plus or minus maybe 5 lbs. So, your compression is low to start with, and the 65 lb cyl could be a problem. Could be from sitting for a while, as you mentioned. I'd run a can of Bombardier Engine Tuner through the powerhead-according to the instructions on the can. Likely you will see the compression increase somewhat and probably idle much better. If the compression comes up a even a little, your compression numbers will be in the ballpark. If the low cyl is still more than 10% lower than the rest, you need to have a look inside. 1. Shine a pencil flashlight into the low cyl and visually inspect. Check the piston crown for pits. Check the cyl side walls for scuffing. 2. If you see anything unusual pull that head. 3. If you pull the head, move the piston around by hand at top dead center and see if you cant determine if the top ring is intact or not. (there should be enough slop in the piston-to-liner clearance for you to do this.) Pits on the top of the piston and underside of the head face are from pcs of the top piston ring-after it disintegrated. 4. You can pull the bypass cover off the low compression cyl and have a look at the ringsets. Look at the skirt of the piston to see if it has a carbon ring buildup on it. (the decarb process should start to eat away at any carbon ring.) If the engine runs normally at wot (5000 rpm's) it's unlikely the fuel pumps are bad. [Although that engine should be propped to run at least 5500 rpm's at wot.] The carb bowls on that engine have mid-range jets in addition to the idle and high speed ones. Possible one or more of them is plugged with debris-causing the midrange stumble you mentioned in your first post. When you pulled the carbs down for cleaning, did you pull all the jets out for a visual inspection for debris? - a must during any carb cleaning. That could be part of the problem.
