Re: Replacing Steering Arm on 1998 Johnson 115
I have the exact same model and problem. My steering arm is "scarry" rusted. I am afraid it will break at WOT and the engine torque will slam the engine hard in one direction, violently turning the boat and injuring passengers. I have read several descriptions for replacing this part ranging from fairly simple to extremely difficult. The 'simple' process I read is to secure the engine in a hoist (still attached to the boat)remove the bolts at the top (top bolts are at the aft end of the steering arm itself) and bottom of the stern bracket , pull the engine away from the bracket, then remove and replace the steering arm assembly.
If this procedure is correct I would try to do it myself. Rusted bolts would be a challenge to remove though.
The extremely difficult procedure I have read is that the power head must be pulled (per a marine mechanic) then the lower unit removed. I have searched the internet and still can't confirm the correct procedure and apparently the service manuals don't describe an R&R of the steering arm. If anyone has done this as described above in the 'simple" procedure, please let us know. Thanks!
