Re: 1986 Evinrude 60 hp gearcase oil?
The oil must say it is for marine applications. Automotive 80/90 won't cut it. The HPF pro is an excellent marine grade oil. The Merc High-Perf is also excellent. You just need to be sure the oil is a "hypoid" variety (will mix with a little water and still maintain lubrication properites.)
