I bought this awsome pontoon yesterday!!! It has a good ole 65 triumph circa 1973. Model 65373R. Drained and flushed the carb bowls, changed the lower unit oil. Fresh gas can from my other boat. Started it and it runs great! Compression tested it after running it and it's 118, 118 and 115 on the bottom. It did stay cool, i plan to do the thermostat and a water pump impeller, ordered the parts on Iboats today as a matter of fact. I took it for a good long cruise with 6 friends and did periodic checks to make sure it didn't feel or smell hot and it's running quite well. It needed a rectifier, had bummed wires on the back and had obviously been cracked from time and then touched and got hot, tested and no luck on charging, so I substituted a 4 wire rectifier from a newer model i had laying around and left 1 wire unhooked and it charges perfectly now. I did check the stator and it checked to the spec i could find, at least both wires had the same resistance, and with throttle the stator made 30-40 volts AC, so i think my rectifier swap is the fix there, at least temporarily. I have wrangled these charging systems before.
Here is where my problem lies, the wires coming from the head, i believe it's where the "thermo switch" pn 384088 is located were unhooked when i bought the motor. Does anyone know how this thermo switch works on this motor? Normally open, normally closed, does it work on a change in resistance? I am assuming that these 2 wires hook to the power pack, but the labeling isn't adequate enough to hook it up being certain that i am not going to fry something. I want to test this switch, and hook it up properly if it works, or replace it if it doesn't, but i am not sure how to test it. I looked in the sticky thread at the top and wasn't able to locate wiring diagrams... I am fairly handy with my volt meter, and basic knowledge got my this far... but sometimes it isn't enough and I must bow to the experts... and beg for your help. I would love to have this motor working 100% so i can have piece of mind this summer and have good times at the lake, as is, it could overheat and i would never know until it was WAY too late...
Many thanks in advance.
Adam
Adam
