norman2013
- Dec 8, 2013
- 154
Hey guys, Over the winter i purchased a 65 hp johnson that I beleve is between a 1984-89 year. The model tag is missing on the motor. I put this motor on my pontoon boat and went to the lake to test it out and it has now problem starting up. But when I go and put it in gear it runs for a second then cuts off. I let it warm up for a good 10 minutes and try it again and it did the same thing. I noticed it wasn't pumping water and wasn't sure if it had something to do with it n to pumping. I plan to replace the impeller and I wasn't sure if this problem could do with a bad thermostat? Also when i tried to put it in reverse the buzzer was going off, but not in forward? Any help would be great! thank you!
