surethatworks
- Aug 21, 2012
- 7
Couple of questions I'm hoping someone has some knowledge on.
The warmup lever seems to engage itself slightly each time you go to full throttle and back down to idle... not to big of a deal, you just push it down sl;ightly and the rpms return to a normal idle. Anyone had this problem before? Easy to live with if no one has.
The second is there is like 0 throttle response in reverse. I installed new cables and have everything adjusted properly... just even at the controls there is not much "reverse" only goes back like an inch before the trottle will not go any further. Is this normal?
