I finished the ignition problem. Working on fuel. I need a new fuel filter and nut, and was wondering the correct part numbers are. Glass bowl also needs the o-ring.
Can anyone help with the part numbers? One reference I found stated for a similar engine:
Filter OMC 303133
Gasket OMC 303122
Glass bowl OMC 303121
I need the filter, the nut which attaches it, and the 0-ring (or gasket) to seal the glass bowl. Bowl is there, just nothing in else. I need confirmation on p/n-s and any suggested source for purchase.
Thank you,
JimVmd
Filter OMC 303133
Gasket OMC 303122
Thank you,
JimVmd
