evinrude55
- Feb 22, 2014
- 8
I went to buy a late 1970s evinrude 135 today. The motor was very clean and appeared to be taken care of. I first decided to check the compression.
Top left was 150
Bottom left was 125
Top right was 125
Bottom right was 125
The 150-125 raised concern. Although started the motor, idled and revved excellent. everything seemed to be ok. The owner said It had maybe ran 30 minutes in 3 years. After running it for 5-10 minutes we turned it off I checked again.
Top l 145
Bottom l. 120
Top r. 120
Bottom r 105
I probably would have bought it if the bottom right didnt say 105 and had stayed 120. The owner who seemed knowledgeable said if I ran it that everything would even out. Is this true or did I make the right decision not purchasing?
Original price was 1100 when they said compression was 125 on all four. I offered 700 they said nine would be the lowest. After leaving they called and said 800. Thoughts?
Top left was 150
Bottom left was 125
Top right was 125
Top l 145
Bottom l. 120
Top r. 120
Bottom r 105
