stratosrookie
- Nov 18, 2010
- 7
I have a 2001 Johnson 200 hp motor. The motor will run fine most of the time, but sometimes I get intermittent firing on the #3 cylinder. I have replace the power pack, the wires, plugs, and the coil pack, but it still intermittently fires on #3. I can understand an entire bank not firing, but I can't seem to identify the cause of this problem. It seems to do it after the engine warms up. When it starts to intermittently fire, I can turn the engine off and restart it several times and it always eventually begins to work again. Sometimes it takes two or three times of doing this and sometimes it may take a dozen or more. When I am at home trying to test the engine everything works fine.
