knotquilty954
- Mar 5, 2014
- 8
I have a 1983 90hp evinrude M#90TLCOS. I am constantly having to charge my batteries every time I use my boat. Where or what should I check first. Thanx
Knot , welcome aboard! if you have a 12 volt test light, you can disconnect the positive battery terminal then connect one end of test light to positive battery terminal . the other end of test light to the positive wire you just took off battery, if the light burns you have a current draw from battery, then disconnect the positive (red) wire from rectifier, if light goes out rectifier is bad. good luck:joyous:
