crashkaloop
- Jun 5, 2013
- 54
Hope I can get some help on this one?
I have a 1989 Johnson GT 175 and I want to re-jet the high speed orifice. The current jets are 61C, which is one of the standard jets listed in the parts diagram, listed as part # 0320661. They also list a 56C as part # 0325019. These appear to be the only high speed orifices available.
I operate at lakes at 6,000 to 8,000 feet in altitude, and my plugs are fairly wet most of the time (running too rich).
I measured the actual opening size of my jets and they are 61 thousands, so I now know what the 61C stands for in the part number. And that now tells me with some confidence that the other jet in the parts list (56C) would be 56 thousands orifice.
1) Are these the only two options available for my engine?
2) Is the 56C jet likely to be the correct jet for my altitude?
I know that some will tell me to change my prop, but I truly want to re-jet because I know the engine is running rich.
Thanks for the help!
