Johnson 150 Carb Intake Leak
Have been experiencing a high idle (among other things).
Ran at idle, sprayed carb cleaner on the port side where throttle body meets the intake.
Idle went down 100-200 rpm.
Same results when spraying next to all three carbs, so intake appears to be leaking all the way down.
Tightened the mounting bolts a little - same results, idle went lower when carb cleaner was sprayed.
Starboard side ok.
Took off the three carbs - Rubber seals (gaskets) between carb and throttle body and between throttle body and intake look good and are fairly new. Throttle body looks very slightly warped after putting a straight edge down the length but I am not too inclined to replace it at $450 a copy.
My question is this:
These gaskets (seals) are thin and flimsy and don't seem to protrude enough to get a decent seal.
First: get a new set of gaskets.
Then put some OMC gasket sealer equivalent like Permatex aviation sealer on both sides of the gaskets to promote a better seal and essentially increase the thickness a little. Install, let dry overnight.
Any input would be appreciated.
Starboard side ok.
