Bryan Sumrell
- Dec 28, 2013
- 10
I am in the process of restoring a 1974 15' Thunderbird tri-hull, I originally tried a 1998 50hp Evinrude and did not like the performance and have now installed a 1974 70 hp Johnson. With both of these motors and with 2 different tachs they do not act right. With both motors the tach will get to around 4,000 and fall back and then act erratic. If you run up to 4,000 and hold the tach will stay for a little while. 2 different motors and 2 different tachometers same problem. The 70 will be permanent and would really like to get the tach working properly. Thanks, Bryan
