HAVE A 1989 EVINRUDE 150xp. ENGINE DOES FINE WITH FULL THROTTLE, BUT IT WILL NOT IDLE CORRECTLY.
S samtech Seaman Apprentice Joined Aug 24, 2013 Messages 45 Feb 28, 2014 #1 HAVE A 1989 EVINRUDE 150xp. ENGINE DOES FINE WITH FULL THROTTLE, BUT IT WILL NOT IDLE CORRECTLY.
R racerone Supreme Mariner Joined Dec 28, 2013 Messages 36,306 Feb 28, 2014 #2 Re: Evinrude will not idle Not much information was posted on what happened here.--------So I would start with a compression test.
hall832 Petty Officer 1st Class Joined Sep 6, 2012 Messages 234 Feb 28, 2014 #3 Re: Evinrude will not idle Fuel, idle circuit has restriction in the carbs.
B boobie Supreme Mariner Joined Nov 5, 2009 Messages 20,826 Feb 28, 2014 #4 Re: Evinrude will not idle As said above, start with the compression test and then you know what you have to work with.
