I was having issues with motor running under a load. I checked compression 120 on all four cylinders. I checked the spark and I have issues with top port cylinder. on the spark tester it won't spark unless you keep cranking it and then it will fire only once or twice and then it will stop sparking again. Where do I go from here. I have no adapter for testing the power pack or ignition coil. If I replace both should this fix my issue? any help would be great, I just bought this boat and it's my first so I'm learning as I go. Trying to make heads or tails of the Seloc Manual (they don't make an OEM for my year motor).
