Pacifictimes
- Oct 22, 2010
- 35
Yesterday I found the key sheared so I replaced it (OEM) tightened it (my tourqe wrench only goes to 100psi so I took my large 1/2" rachet and got another quarter turn on the nut. I also spent about 30 minutes with rubbing compound on the shaft cone and the flywheel cleaning both surfaces up. About two weeks ago I had this engine running (rough though) I put it in the river tied to the bank, it ran around 10 minutes at a high idle, some missfire but was not real concerning to me, I was hoping it would just clean up and run smooth. When it sounded like it was smoothing up it then died, haven't been able to start it since. Now that I have found and replaced the key I would like to check the timing but dont know if this can be done, especially if the motor does not start.
I bought a timing light but have never used one. (yet)
I appreciate your time and advice - Dave
