Newbie here, find good info, but need help. I'm no electronic engineer, and my VOM meter is foreign and not utilized much.
Anyways, got spark in lower, not upper.
So, I do the coil checks, and though it has two differing aftermarket, both appear in good shape. Primary checks, and I get some resistance on both secondary, I think. I hit ground on the coil, and end of each spark plug boot. running meter at 20K ohm, shows something like 4.3 display on one coil (a black one) and 3.6 on the green one (like sierra coil). The green one is on the upper bad. No spark using tester on upper, so it is not a case of bad plug.
OK experts, tell me what to do. Am I hitting the right points on the probe to test secondary coil? Do I have a simple spark plug wire short? Are the reading telling me something I don't understand?
In a "go-figure" state, gotta be an easy solution, just don't care to be in a replace all stuff position, but I can I guess. Points look good, gapped, condensers are just that, conns are tight.
Coil suspect I think.
