I just joined and am looking for some help. I have an old Johnson-super seahorse out board, I'd imagine its around 30-40 horse but am not positive. When I take the boat out the engine runs and then when I put the boat in gear it cruises. When I go decently fast the whole engine kind of pops and bounces the transom. Is this pre ignition or something like that? I thought it may have been the hub on the prop so I replaced it as well as the plastic coupling and cotter pin and the pin that holds the prop on the shaft. I would like some help or suggestion?!
Thanks,
Specs
Thanks,
Specs
