Re: jw 10 rope start install
Actually, you can use a nylon rope with a knot. However, you must be extra careful not to pull the rope all the way to the end. If you do, it will cut the knotted end off, the pulley will go flying back, and destroy the recoil spring. If you get lucky enough, there is such a thing as a later model pulley designed for a knotted rope. It has a pin that prevents pulling the sharp edge against the knot. I have also retrofitted a few old pulleys with a pin.
