backstop13
- Dec 2, 2013
- 19
Hey guys, have a question for the Evinrude/Johnson "experts". I recently purchased another CC boat with a 1998 Johnson 130 J130TLECE and noticed some odd things around the engine. First, the VRO has been disconnected, which doesn't bother me, but I also noticed the port side temp sensor tan wire has been disconnected. We ran the boat on muffs at the sellers house and it purred like a kitten, shifted smooth, and responded to all of the throttle controls. My question is: Will the disconnected tan wire to the port side temp sensor have any affect on it's performance or cause the alarm to go off or the engine to overheat? I have read that disconnecting the temp sensor has no bearing on performance but could affect cold start, is that accurate?
My other question is: Is premix REALLY better than using the VRO, or is it even relevant? I'm not worried about fuel efficiency, it's a V4 130, but every little bit helps nowadays. Also, I'm upgrading from an 18' CC to a 20' and going from an Ocean Pro 115 to this big Johnson, did I make a mistake giving up the Ocean Pro for the 130? I hear the late 90's Johnson, non ocean models, were virtually indestructible and that's what I'm looking for.
As always I appreciate any input, opinion or fact.
thanks
thanks
