Abomb27
- Jan 6, 2013
- 141
I have a 1996 Omc 115 turbojet, that I am going to rebuild. It is fully disassembled, and I just dropped it off to the machine shop. They are going to check the bore, and hot dip the block to clean it up. BUT they told me they cant bore it if it needs it. Hopefully it doesnt need it. I want to post my progress. First motor I am rebuilding, I find it interesting, hopefully I can het dome advice about things people have learned while doing theres. Im sure I will have questions along the way. And boobie if you read this I talked to you awhile ago about this motor missing a ring on 1 cylinder. There was almost no damage anywhere. The guy at the machine shop said all the walls looked good. One cylinder had some scratches that he said he couldnt totally get out with a hone. But not anything to worry about he said. I believe it wasnt put on, dont know what else to think. He said if a ring went the walls would be toast.
