Hi all - hope you can help me. My 1972 Evinrude 65hp (65272) won't start and I think it's a spark problem.
* No apparent spark on any plugs when holding them against the engine block
* When I hold a screwdriver into the HT boot and place it near the block, the spark jumps at about 5mm (1/4 inch) and looks very weak
* Brown wires (4 and 5) to the stator show around 78V AC when cranking the starter. (Bear in mind the battery is a bit low so cranking wasn't at full power). Thought this was meant to be about 300V
* Have tried disconnecting the key switch ground wire (#6) but no change
* Had a flat battery just before this trouble. When I got it going on a jump start, there was only a marginal voltage increase across the existing battery (0.5V) with the jumper leads removed so I suspect a bad rectifier.
Can't help feeling the low spark and no battery charging things are related and seem to point to stator or power pack? I'm trying to pinpoint what part is faulty as I'd prefer to only replace the bit that needs fixing, (ie don't want to spend lots of money!)
Any thoughts?
Any thoughts?
