Re: '74 evinrude 15hp shift shaft seal
Thanks guys! I made a puller out of 1/4-20 all thread and pulled her out. All te gasket sealer they used on it really kept that girl I there!! I even bent 1/4 steel plate as I screwed down to it. The filed down nut worked great. Thanks fellas.
Now I have a little problem. All is well and I got the whole gearcase back together. Detent balls are in place because it pops into gear perfectly. But I made a booboo and tapped the driveshaft seal in about 1/8" too far. You can see in the photos.
It looks to me that the seal,even if in its proper position will hold water under the waterpump even after it "drains" my concern is the with the seal a bit lower than factory that it will contain more water and will possibly freeze up and break something.
So I need your opinions guys. This is a spring/summer/ fall motor and comes off the boat after each trip. Do I fork out the $20 and 1/2 hour ride and go get two new seals, pulling these fresh seals out? Or do I let it ride with confidence?
This is a friends motor also.
